WiFi / Ethernet connectivity issues
Author biasi
#16 | Posted: 26 Apr 2020 11:25
you have to click on Cloud and then on "Cloud User" to create a user;once the user is created you have to click on Cloud and then on "Cloud Refresh"
Author zmas Male
#17 | Posted: 12 Nov 2022 14:21
biasi
Has the root password changed? I'm also having issues with direct ethernet connection and I'm trying to SSH into the PGenerator but I can't get access to root with that password
Author biasi
#18 | Posted: 12 Nov 2022 14:55
The root password is not changed. Which iso are you using?
Author zmas Male
#19 | Posted: 13 Nov 2022 08:30
I'm using TedCalibrationDisk version of PG 1.3
It's just that I'm having issues connecting the PGenerator to my machine, which is running on a VM on an M1... So ARM CPU and VM double trouble...
Author Omardris
#20 | Posted: 13 Nov 2022 11:12
The PGen version of TedCalibrationDisk uses a different password.
Peter
Author Sir_CYBO Male
#21 | Posted: 24 Sep 2024 12:57
Can someone help.
My RPi PGen is seen by Calman Home but not Lightspace CMS. Any clues?
Regards,
Sid
#22 | Posted: 24 Sep 2024 16:46
Disable your firewall to test if it's blocking your LightSpace's network access with the PGenerator.
