Problem updating PGenerator
Author Miksu
#1 | Posted: 18 Dec 2019 14:57
Looks like the latest image of the PGenerator has invalid address for updates:
Getting packages list from master/BiasiLinux/repository/RPI/armv6l/list.packages...done (exit_code: 22)
Error getting conf packages list from master/BiasiLinux/repository/RPI
Author biasi
#2 | Posted: 18 Dec 2019 23:31
can you try again now?
Author Miksu
#3 | Posted: 19 Dec 2019 07:17
biasi
Thanks, it works now. Didn't realize master/ was actually a valid address, that's why i assumed it was wrong.
Author biasi
#4 | Posted: 19 Dec 2019 12:04
the name master is configured in file /etc/hosts with ip address 85.89.129.58;there was a problem on my Linux Repository and so the devices with armv6l didn't work but now all is ok
Author Miksu
#5 | Posted: 26 Feb 2020 14:05
I'm having the same problem again (armv6l) not getting the package list.
/Miksu
Author biasi
#6 | Posted: 26 Feb 2020 14:21
I have resolved definitively the problem about arvm6l;can you try now?
Author Miksu
#7 | Posted: 26 Feb 2020 14:27
Didn't expect this fast of a response.
Now it got the list, but another error:
root@PGenerator:~# pkg_update
Getting system info...done
System Project: RPI
Getting packages list from master/BiasiLinux/repository/RPI/armv6l/list.packages...done (exit_code: 0)
Package dhcpcd with version 8.1.6 need to be updated to version 8.1.6 [Default]
Getting metadata package master/BiasiLinux/repository/RPI/armv6l/metadata/dhcpcd-BiasiLinux.tar.gz
######################################################################## 100.0%
File downloaded: /var/tmp/BiasiLinux/dhcpcd-8.1.6-armv6l-metadata.tar.gz
Getting binary package master/BiasiLinux/repository/RPI/armv6l/packages/dhcpcd-8.1.6-armv6l.tar.gz
curl: (22) The requested URL returned error: 404 Not Found
Author biasi
#8 | Posted: 26 Feb 2020 14:35
try to do this:
pkg_reinstall dhcpcd
and then pkg_update
Author Miksu
#9 | Posted: 26 Feb 2020 14:37
root@PGenerator:~# pkg_reinstall dhcpcd
System Project: RPI
Tried also with: pkg_install nano - same error.
Author biasi
#10 | Posted: 26 Feb 2020 14:47
try now
Author Miksu
#11 | Posted: 26 Feb 2020 14:48
Works perfectly.
Author biasi
#12 | Posted: 26 Feb 2020 14:53
with this update you can also connect your pc directly to the rpi with an ethernet cable because the new dhcp client "dhcpcd" is an IPv4LL (aka ZeroConf ) client
Author Make73
#13 | Posted: 26 Feb 2020 19:26
biasi:
For DeviceControl IP = 0
How about checking updates with PuTTY when connected directly to laptop?
Tried host name PGenerator and IP 0, so succes.
(I have latest, re-flashed, just tried it)
Author biasi
#14 | Posted: 26 Feb 2020 22:21
if you connect rpi directly to laptop, to make the update procedure work, it is necessary to enable the share on the laptop network card that goes on the internet (e.g. wifi);to enter with ssh on the rpi you have to configure the ip address assigned by new dhcp client daemon and you can find this ip using the section Net in Admin DeviceControl Template (the assigned IP will be of the class 169.254.0.0/16)
Author Make73
#15 | Posted: 27 Feb 2020 04:20
Thanks biasi
I had before few read errors when connected through router, now when directly connected to laptop it works like dream
