PGenerator Pre Calibration Test Patterns
Author dlamon1 Male
#1 | Posted: 14 Dec 2024 17:24
Does ColousSpace provide control to output the pre calibration test patterns, flashing black and white bars, from PGenerator ?
#2 | Posted: 14 Dec 2024 17:45
Yes.
https://lightillusion.com/pgenerator.html#integration-2
Author dlamon1 Male
#3 | Posted: 14 Dec 2024 19:28
Just for clarification, as I was raised a luditte, I need to purchase this through Ted's website and load that iso, correct ?
#4 | Posted: 14 Dec 2024 22:20
That will depend on if you want Ted's ISO with all his additional test patterns.
#5 | Posted: 15 Dec 2024 15:25
dlamon1
You can purchase Ted's PGenerator ISO only from Ted's website, it's not available anywhere else.
The regular ISO doesn't contain patterns (static or flashing) for pre-calibration.
You can enhance your license to allow ColourSpace to inject those patterns. (more info)
Author dlamon1 Male
#6 | Posted: 26 Dec 2024 23:17
I have purchased the ISO via Ted's website and still do not see the test patterns.
#7 | Posted: 27 Dec 2024 12:44
Have you followed Ted's instructions on installing, etc.?
If so, they will be there.
#8 | Posted: 27 Dec 2024 12:55
dlamon1
OK, you will need to send a request for a free license enhancement to inject the patterns using ColourSpace's GUI.
https://www.avsforum.com/threads/teds-lightspace-cms-calibration-disk.1454804/post-61850665
That info is available in the email with Ted's PGenerator order.
Author dlamon1 Male
#9 | Posted: 29 Dec 2024 00:37
Ah I didn't see that, I needed to read further. Thank you both for the help, currently up and running.
