PGenerator 1.6 no HDR output
Author BjornRuud Male
#1 | Posted: 20 May 2024 18:26
I'm using PGenerator 1.6 and when connecting in ColourSpace 1.0.0.1918 nothing happens when I try to output HDR/DV. The resolution selector is empty and the EDID button shows blank output, could that be the problem? Or have I misunderstood how it works, I thought you could set patches to off, set HDR, enable patches and then PGenerator would output a HDR signal?
#2 | Posted: 20 May 2024 19:08
As per the software release notes:
-- Includes pre-release of EDID viewer
(Not presently working with PGen)
And yes, PGen will send HDR if enabled correctly.
Sounds like you do not have the configurations set correctly?
#3 | Posted: 21 May 2024 14:24
Ensure that you have enabled the enhanced HDMI color from your TV's HDMI port.
One of the Pi4 HDMI ports is the 'correct' port.
If you use a case with two micro-HDMI ports, the correct port is the one near the USB-C.
If you use Argon ONE with standard HDMI ports, the correct port is away from USB-C.
You can use the Settings Template in DeviceControl to check your HDMI port; click the EDID at the bottom of the Template.... it has to populate data only for the HDMI A1 port when you use the 'correct' port.
https://www.lightillusion.com/pgenerator.html#integration-2
https://www.lightillusion.com/zippdf/pgenerator-guide.pdf
#4 | Posted: 21 May 2024 18:24
I was running on a Raspberry Pi 3. With the Pi 4 it worked. I have to start labelling them.
#5 | Posted: 21 May 2024 21:33
I have my 3b+ and 4 in different case styles. No confusion that way.
Online now: Guests - 9
