LG C8 WOLED 1D & 3D LUT Calibration - LightSpace and DeviceControl
#1 | Posted: 7 Mar 2019 16:35
With the latest version of LightSpace (presently in Beta Testing) we have added the ability to export 1D and 3D LUT for use with DeviceControl for direct loading into compatible LG TVs, such as the C8 WOLED.
A User Guide can be found HERE.
#2 | Posted: 7 Mar 2019 17:28
Note: All aspects of the LightSpace/DeviceControl integration is being handled by Ted at www.displaycalibrations.com, including access to DeviceControl, the LG Template, etc.
Author sat4all
#3 | Posted: 8 Mar 2019 08:05
Thanks Steve,
Warming up while waiting for TED to send me the necessary files.
Author Chad B
#4 | Posted: 8 Mar 2019 22:03
New user here. At step 3, when I export it doesn't have a selection for DeviceControl 1D LUT. It has: eecolor, LG, Light Illusion, and Video Card Gamma Table.
I am having similar problems with other guides and instructions; they tell me to do things that I cannot find options or selections for.
#5 | Posted: 8 Mar 2019 22:12
The present DeviceControl integration for LG C8 TVs is in Beta release.
The main release will be in a day or so.
(The info here is a bit in advance of the main release).
As for other guides having information you cannot follow, you will have to be a lot more specific.
#6 | Posted: 9 Mar 2019 11:16
I've added an initial DeviceControl User Guide to the main website pages.
Have updated the first post to reflect this change.
We are still on Beta Testing, as we have a couple of issues to sort, and Ted is in charge of all Beta Releases.
Author rbhun
#7 | Posted: 12 Mar 2019 23:45
Hi
I have got the download email, but thatpointsto a version from last December, which does not seems to have LG control in it, only Panasonic. The changelog is from December too, as well as this other link on the avmagazine.it
would the December version (2.0.15) control LG OLEDs, or is there a newer version?
#8 | Posted: 13 Mar 2019 07:42
Please see post 2 in this thread...
#9 | Posted: 25 Mar 2019 07:47
Calibration results from users with the new DeviceControl LG Template are starting to come in... and the results are fantastic!
https://www.lightillusion.com/forums/index.php?action=vthread&forum=13&topic=374&page =2#msg3186
Author Chad B
#10 | Posted: 20 Apr 2019 19:22
The user guide says to log in to device control. What is it talking about? I am at localhost:81 and see nowhere to log in, either there or in the device control text box.
Author biasi
#11 | Posted: 23 Apr 2019 15:57
once you have opened the browser on /localhost:81/ you have to create a new device of type "Generic Websocket" configuring in the field "Device Ip" the ip of your tv and then you have to register to Cloud to be able to access device templates
#12 | Posted: 23 Apr 2019 16:00
I've also updated the User Guide with more specific info...
Author AndrewH
#13 | Posted: 4 Jun 2019 21:24
First time poster here and researching Lightspace. Does the LTE version allow/include LUT generation and upload to LG OLEDs (C9)?
Thanks in advance,
Andrew
#14 | Posted: 4 Jun 2019 21:28
Hi Andrew - please see the website info on DeviceControl.
That works with LightSpace for LG use, including the LTE version.
The C9 is in progress of being added to DeviceControl.
Author fonsocm
#15 | Posted: 11 Jun 2019 13:30
Hi.
Is it possible to calibrate to Rec2020 or HDR?
In the topic in avsforum, the people calibrated to SDR. And the new material, today, is almost UHD (without HDR) or HDR.
Thanks.
