LG 2019 Device Control Template Password Issue
Author stuart_p
#1 | Posted: 30 May 2020 03:30
Hi, have downloaded the new template for LG 2019 and have an issue when password entered. Get this message in cmd window - Thread 1 terminated abnormally: Initialization vector must be exactly 8 bytes long when using the Blowfish cipher at C:\Users\stuar\Desktop\DeviceControl/pm/get_command.pm line 323 thread 1
All the other new templates worked fine that were 29/5 or 30/5. Just this one keeps going round and round until you crash out and also need to crash out Device Control. Have deleted the template and tried to reload, same result.
many thanks
Stuart
Author biasi
#2 | Posted: 30 May 2020 11:29
which perl version is installed on your system?
Author stuart_p
#3 | Posted: 30 May 2020 12:53
HI Biasi
Was on 5.28.0.1 Strawberry Perl, just upgraded to 5.30.2.1 and same result. Device Control was updated the other day to 20.0.19 12th April. Other templates, such as new PQ curves and B9 installed fine, only the one template causing issue.
thanks
Author biasi
#4 | Posted: 30 May 2020 16:14
can you check inside the file saved in conf dir if the string IV is present?
Author stuart_p
#5 | Posted: 31 May 2020 01:29
HI Biasi
In the \DeviceControl\conf\LG C8\Memory\2019 REV.4.txt there is IV=LyBoqeQCgwo=
tks
Author biasi
#6 | Posted: 31 May 2020 01:50
I have found the issue; I will publish new version very soon.
Author stuart_p
#7 | Posted: 31 May 2020 03:09
Thanks Biasi. Can conform new version worked.
Online now: Guests - 9
