HDR vs SDR pattern
#16 | Posted: 17 Aug 2021 21:16
Someone with PGenerator with HDFury can check and compare.
#17 | Posted: 17 Aug 2021 21:56
Lttlwing16
It will require defining mastering monitor parameters (black/white/maxCLL/maxFALL), colorspace, and white point.
HDFury Linker (or better models like Vertex, Vertex 4K60, or Integral 2) can inject all these parameters.
Author Lttlwing16
#18 | Posted: 20 Aug 2021 11:57
ConnecTED
Thanks Ted,
I have a proper set of HDR files on a USB drive, but would have to manually measure. Could I use these to compare?
I assume there would be increased error if the Sony TV HDR Video mode was not an effective method compared to the USB files
#19 | Posted: 20 Aug 2021 16:13
Lttlwing16
If you know the exact RGB triplets for these files to be able to create and use a custom patchlist, then it will work.
Author Lttlwing16
#20 | Posted: 20 Aug 2021 20:53
ConnecTED
If the USB HDR files with metadata measure the same as Pgen + HDR mode on Sony then safe to say the Pgen + HDR Video Mode is accurate
Author tsanga
#21 | Posted: 21 Aug 2021 17:17
I suspect that Sony HDMI settings [HDR mode -> HDR10] would be similar to LG HDR override, where 8 bit grayscale is scaled appropriately for PQ tracking. In other words, this would be ok to use for grayscale.
 HDR vs SDR pattern
Online now: Guests - 6
Members - 1 [ twitt88 ]
