Connection issues with Lightspace
Author PaulWillis
#1 | Posted: 20 Jun 2019 14:21
Hi folks,
I can't seem to get my PGen to connect to Lightspace. The IP shows up under 'Server IP Addresses' but always shows '0 available clients' with Network Controller enabled. Tried both Wifi and ethernet and I have managed to get Device Control to connect to the PGen via WiFi, so I'm not sure where the issue is. Firewalls are disabled. I'm assuming the PGen is booting properly, my monitor shows command line booting for 10 seconds or so then it goes to black.
Is there something simple that I'm missing?
Many thanks for any help.
Author PaulWillis
#2 | Posted: 20 Jun 2019 16:10
Scratch that...solved it, it was a firewall issue. Borrowed a work laptop riddled with very stubborn Norton protection....
