Configuring PGenerator at DeviceControl ?
Author Make73
#1 | Posted: 20 Dec 2019 18:51
https://translate.google.fi/translate?hl=fi&sl=it&tl=en&u=https%3A%2F%2Fwww.avmagazin e.it%2Fforum%2F88-calibrazione-proiettori-e-display%2F301272-rpg-rpi-pattern-generato r-by-biasi
"If you want to configure Wi-Fi access and / or change the RPI configuration, search for an Admin module in the Cloud, load it in Local (drag), connect and click on the Admin module.
Also from the Admin module it is possible to change the setting of the HDMI port from RGB full / limited to YCbCr full /"
Read about Admin template and how you can configure from that.
I have no idea how to get or create such of template, anyone could help?
I have connected PGenerator, PC and TV with ethernet to my router.
I made new device at DeviceControl with right IP-adress but I can´t see only my LG C9 where to connect or disconnect.
I can see and use PGenerator at LightSpace Network Manager.
Do I have to configure PGenerator before I can make 3D LUT profile with LightSpace?
Updated PGenerator to latsest release.
"You only need from there to change the output resolution to 1080p24 and change to 24Hz.
Be sure also that you are sending an RGB-Full signal."
Got that kind of instructions but don´t have any idea how to do that
EDIT:
Found it already, I didn´t realize that I have to Press LG C9 and under that is list of devices
There I choose PGenerator and when connected updated cloud and there was already made templates where I could set 60Hz-->24Hz
But maby someone other newbie struggle with same thing so maby not should delete
Now to make first profiling with LS.
Members - 1 [ Kuky ]
