X-Rite i1 Display Pro OEM - Calibrite Software
Author zmas Male
#1 | Posted: 18 May 2026 08:39
I need to calibrate my Macbook Pro display with an ICC profile. I had the display replaced and it's very far of from target.
I own an OEM version of the i1 Display Pro, which supposedly doesn't work with i1 Profiler/ Calibrite Profiler 3. is there a workaround for that? or can I profile the display wiith colourspace and create an ICC calibration profile?
I have Lattice, which can export in .icc. Can I profile the display with CS export a lut and just convert it to .icc with lattice?
#2 | Posted: 18 May 2026 11:02
You can profile any display with ColourSpace, generate a LUT, and convert to an ICC with SpaceMan.
#3 | Posted: 20 May 2026 18:34
i1Profiler needs a Retail meter, but it can measure only 478 colors to create an ICC, which is a very low number.
Author zmas Male
#4 | Posted: 21 May 2026 14:15
What solutions are there to display the patches on the MacBook Pro? I have a dedicated PC Laptop for lightillusion.
Author zmas Male
#5 | Posted: 21 May 2026 14:18
And how do I set the display to it's native state? Can I just convert a unity LUT into an ICC profile?
#6 | Posted: 21 May 2026 14:20
If you do a Search on these forums you will find PatternSpace.
It can manage/disable MacOS colour management too.
