X-rite i1 display pro- DCI P3 white point Reddish after calibration.
Author launchpad Male
#1 | Posted: 18 Mar 2024 15:21
Hi, I am using HCFR + X-rite i1 display pro for Monitor and Projector calibration. But recently i am facing issue.
After calibration white point DCI-p3 (X: 0.314 ,Y: 0.351) overall image is visible reddish which should not be the case.
While calibrating , I am entering value of Whitepoint and RGB (x, y) into Projector MCGD (Measured Gamut) and DCI projector do the rest. P3 Target x:0.314,y:0.351.
Earlier result was fine. Now a days there is difference between what we see visually and what probe readings are indicating.
We can see magenta pink tint on screen but probe reading is seen different.
i1 Display prob reading showing correct but visibly it is wrong. How can i correct it. Any way to recalibrate i1display probe itself.
#2 | Posted: 19 Mar 2024 09:46
I would suggest getting ColourSpace so you can verify the calibration accurately.
