What Meters to Calibrate Christie 4K Projector?
Author Russ
#1 | Posted: 29 Sep 2017 18:43
Hello everyone. We have a Christie 4K projector that we use for color grading. We've outsourced our color calibration to a theater install company but we're looking to buy meters so we can do it in house more often. What meters would people recommend? Do I need both a colorimeter and spectroradiometer? We'd be using lightspace to double check the internal projector calibration and LUT creation if we decided to go down that path.
Thanks in advance,
Russ
#2 | Posted: 4 Oct 2017 10:57
Hi Russ,
We would indeed suggest a combination colourimeter and spectro.
The K10-A or CR-100 are the obvious colourimeters to go for.
The Spectro could be a Jeti 1501 or CR-250.
If you really want ultra accuracy, and may be looking to calibrate narrow spectrum displays (laser projection for example) a CR-300 wound be the best option.
