Weird Dif EOTF with Default Unity LUT
Author Wolf91074 Male
#1 | Posted: Yesterday 14:34
Do the following
  • open a new profiling window
  • in the Probe tab, select Virtual Probe, connect with it and select i.e. UHD Rec 2020 as OETF
  • in the Settings tab, select the same Colourspace as Target, Default Unity as active LUT and Patch Scale/Resolution Legal/8bit
  • in the measurement tab, load the FullRange Patch (attachment) and measure it
  • you will get a weird Dif EOTF Diagram
  • now change Patch Scale to Full
  • and the Dif EOTF Diagram is as flat as it should be
So, what's going on here. An does this have an effect on LUT pre-evaluation?
The weird DifEOTF
The weird DifEOTF
The flat DifEOTF
The flat DifEOTF
FullRange.zip Attached file:
The Patch File
LG 65G59LS
xRite i1D3 OEM Dell
xRite i1Pro2 Rev. E
#2 | Posted: Yesterday 17:55
Ah - that is just associated with the Virtual Probe.
If you change the bit-depth too you will see the zig-zags also change.
Mind you, it probably should not do that.
We'll look.
