Video Wall Calibration
Author nlucena Male
#1 | Posted: 23 Oct 2024 17:33
Hello, I was curious if I wanted to calibrate a video wall 9x3 (picture attached). What would be the steps or process I would have to take if I use Colorspace? I see that there is the image sequence probe, but I have never used It before. I am still trying to figure out when I would need to use it. It feels like this might be one of those times, but I could be wrong. Please advise.
using Klein K10-A
Jeti-1511
I am still trying to get the model for these LG TVs. Suppose they don't have 3d Lut capability. From what I have been told, they are LCDs.
One thing about the image sequence probe that has confused me is that it says that combined with the way the camera sees the color emitted by the LED walls
So, do I assume I need a camera or not? I am only asking because of the HW I have Klein/Jeti.
I am still trying to get a deeper understanding. I'm sorry if the question sounds dumb.
#2 | Posted: 23 Oct 2024 17:50
As per the Image Sequence Probe user guide, you use the same camera that will be used to shoot the action in front of the video wall.
This is all about making the video wall background match correctly with the foreground actors/objects, as seen by the camera.
https://lightillusion.com/image_sequence_probe.html
If you are just calibrating a video wall as a large TV/monitor, then just calibrate as normal for any TV/monitor.
Author nlucena Male
#3 | Posted: 23 Oct 2024 17:54
Thank You, Steve .
