Teranex Mini SDI to HDMI from Blackmagic
Author funkyworm Male
#1 | Posted: 2 Jun 2016 14:40
Steve (or anyone else) - any experience of using this new box as a UHD/4k LUT? It apparenly supports up to 33-points for 3D LUTs in either the SDi path or the SDi-HDMI route. All this for the low-low-price of £355!
https://www.blackmagicdesign.com/products/teranexmini/models
Any chance that LightSpace will be able to drive it as a patch-gen?
#2 | Posted: 2 Jun 2016 14:44
We have not yet looked at the box for patch generation.
It may not have that capability?
We will need info from BMD, but as yet we have not have any - so it is presently an unknown.
But, LUTs generated with LightSpace CMS work perfectly with the Teranex Mini.
(The only issue seems to be the box is rather noisy...)
Author cemoz101
#3 | Posted: 2 Jun 2016 18:51
Agreed with Steve, the box is very noisy!
#4 | Posted: 6 Jun 2016 15:31
Noisy from a sound point of view (small, fast-spinning fan) or noisy from a signal point of view?
#5 | Posted: 6 Jun 2016 15:57
Ah - noisy fan!
Author kingakhnaton
#6 | Posted: 28 Jun 2016 20:50
Yes, the fan is very noisy. We put the fan into a junction box in the wall. That seems to work.
Author Ryan McNeal
#7 | Posted: 19 Aug 2016 19:52
I can confirm that it is very noisy, but works well. You can have two luts loaded into it. The $80 optional display front-plate is worth the extra cost. Lets you do some basic controls right from the device, such as toggle LUTs and I love that you can see timecode and input/output resolution right there. Helps me trouble shoot quickly. Im using it in my color suite, and to counter the sound, I've placed in a cabinet with some acoustic dampening materials.
It belongs in a machine room or in a cabinet.
#8 | Posted: 23 Aug 2016 08:07
I've been rushed off my feet (building a Baselight room) so haven't had a chance to load up a LUT and have a play; but I did buy the front panel and it seems like a very competent little gadget.
