TCL QM8B Calibration Problem
Author NebulaUK Male
#1 | Posted: 18 Mar 2024 14:34
I am trying to find the control points for this TV but the results aren't coming out in a zig zag pattern as per the guide. They start off like a zig zag and then it becomes more of a rounded off shape is this correct or am I doing something wrong.
#2 | Posted: 18 Mar 2024 17:01
Set your contrast using a pattern with flashing bars, prevent clipping and then scan with LEGAL patchscale to find the code levels for the control points.
#3 | Posted: 18 Mar 2024 18:16
That's what I did do I need to set any specific settings in the colorspace app.
#4 | Posted: 19 Mar 2024 11:18
Which TPG do you use? Which video colorspace output?
Use LEGAL patchscale to scan for the 0-100% range.
#5 | Posted: 19 Mar 2024 15:24
I used Pgenerator with YcbCr444 output with 16-235.
#6 | Posted: 20 Mar 2024 11:47
Please post your Profile, so it can be reviewed.
#7 | Posted: 22 Mar 2024 14:41
It's OK I used it as it was and it produced a great result. For TCL TVs do you recommend rec709 or BT1886.
#8 | Posted: 22 Mar 2024 14:43
We never recommend BT1886, as it is a flawed concept: https://www.lightillusion.com/calibration_issues.html#bt1886
#9 | Posted: 22 Mar 2024 15:04
OK thanks the only reason I ask is because the TV uses this but I presume their is no harm in just correcting the points to 2.4.
