Spears & Munsil UHD HDR Benchmark (UHD Blu-ray Disc) as Test Pattern Generator
Author rafograph Male
#1 | Posted: 1 Sep 2021 08:54
Hi everyone,
I would like to know if is possible to use a Spears & Munsil UHD HDR Benchmark (UHD Blu-ray Disc) as Test Pattern Generator into Colourspace?
I own a LTE license.
Thank you in advance.
#2 | Posted: 1 Sep 2021 10:43
So long as you know the patch Triplet values, and associated Patch Scale settings, any source can be used.
You just need to have the correct patch on the screen, with the same triplet values set in ColourSpace, when measuring.
