SpaceMatch DCM - Control PC GUI calibration
#1 | Posted: 9 Oct 2012 10:57
SpaceMatch DCM enables the colour management of any PC connected displays, avoiding all the problematic issues associated with ICC Profiles when used within the film and TV media arena.
This is a very simple to use program and enables LightSpace generated LUT to be used for PC GUI calibration, totally separate the the normal ICC profile based OS based calibration - this is needed as OS based ICC profiles can cause very unwanted colour issues...
See: http://www.lightillusion.com/spacematch.html
Cheers, Steve
Author Gabriele Turchi
#2 | Posted: 9 Oct 2012 14:12
sounds amazing steve,
is it a 3D lut ? so more accurate than an ICC profile right ?
ps: now i need it for the Mac and possibly cheaper ( in order to offer it to clients laptops , the ones i often work with )
g
#3 | Posted: 9 Oct 2012 14:24
Ah! - A very good question!
But no, it is 1D as that is all VCGT can be...
Would love them to be 3D, but it's not possible.
However, getting the grey scale (white point) correct is a big improvement!
A Mac and Linux version is being worked on...
