Software Tier Compatibility for ColourSpace & SpaceMan
Author schmatt Male
#1 | Posted: 18 Aug 2026 13:31
I know it's mentioned that a 3D LUT is required by SpaceMan to generate an ICC profile. But I can't seem to find the answer to what tiers of ColourSpace can feed the LUT to SpaceMan.
For instance, DPS has the ability to generate and view a 3D LUT, but cannot export. But since SpaceMan is also a Light Illusion product, can ColourSpace DPS feed this generated 3D LUT into SpaceMan directly? Or does it explicitly require a ColourSpace tier that can export a 3D LUT to a file?
#2 | Posted: 18 Aug 2026 13:55
As SpaceMan loads LUTs, you need a LUT to load.
And as DPS cannot save a LUT, it cannot generate a LUT to load.
Author Alexey
#3 | Posted: 1 Sep 2026 19:09
To avoid creating a new thread, I'll ask the question in this one. The description of the SpaceMan program stated:
"ICC Tools will be added to ColourSpace some time in the future
Presently stand alone SpaceMan software and license is provided"
Is work on integration underway or not? As a holder of ColourSpace LTE and SpaceMan, I'm really looking forward to such integration.
#4 | Posted: 1 Sep 2026 19:33
As we always say in response to such questions, we do not comment on any potential developments that are not expected to be in the next release.
But, as per the existing ColourSpace licensing, SpaceMan would only be included with the INF license level.
