Settings for making a HDR 3DLUT
Author sillysally
#1 | Posted: 26 Aug 2016 23:31
Settings for making a HDR 3DLUT.
UB900 Blu Ray 4K player, Lumagen Pro 4444, 4KOLED EF9500 is my chain.
What settings should I use in LightSpace CMS , for profiling and making a 4K 3DLUT ?.
ss
#2 | Posted: 27 Aug 2016 07:46
LightSpace CMS integration with the Radiance Pro for HDR is not yet complete.
(Actually, the HDR capabilities of the Radiance Pro are not yet complete...)
But, for LightSpace and HDR operation there is information in the LUT Management User Guide.
See: http://www.lightillusion.com/lut_manual.html#colour_space_conversion
And scroll down a bit - there are 4 images describing different HDR (ST2084) configurations.
(You may need to pre-load the http://www.lightillusion.com/lut_manual.html User Guide before using the above link...)
The bigger issue is forcing your display into HDR mode.
You may need to use something like http://www.lightillusion.com/murideo_six-g.html to inject the necessary metadata into the HDMI path.
