Samsung Remote Control for manual calibration (Windows)
Author liyi_1991 Male
#1 | Posted: 14 Oct 2026 11:54
Hi everyone,
I would like to share Samsung Remote Control, a small Windows tool for adjusting Samsung TV picture settings over the local network. It has been tested on my Samsung S90C.
It supports:
- Basic picture settings, including picture mode, brightness, contrast and gamma.
- 2-point and 20-point white balance, with all points shown together.
- Colour Space adjustments for RGBCMY, with three RGB controls for each colour.
- undo and settings export.
You can adjust the TV directly from your PC without using the remote or opening the TV menu. This saves time during manual calibration.
The tool works alongside ColourSpace. ColourSpace handles patches and measurements, while Samsung Remote Control adjusts the TV. You select the matching patch manually in ColourSpace.
To connect, enable IP Remote on the TV and connect the PC and TV to the same local network.
#2 | Posted: 14 Oct 2026 12:41
Samsung-Remote-Control.exe:
https://drive.google.com/file/d/1F7WGWtr9dYRuCp0Hpz_vQvKDUuhCa5cA/view?usp=sharing
Samsung_HDR_10bit_FULL.csv:
https://drive.google.com/file/d/18gIM7EllwrdA0Rz0S3MsROVH5qod47dl/view?usp=sharing
Author schmatt Male
#3 | Posted: 14 Oct 2026 14:04
I already created a platform agnostic one for this. See original post here. There have been a few enhancements to this as well.
https://www.avsforum.com/posts/64827699/
Github project is located here.
https://github.com/whipstein/SamsungController/releases/tag/v1.0.6
I'm also currently working on a follow on version that will access the factory service menu and control that too. I'm still unsure as to how I will share that one, since it's more dangerous and shouldn't be attempted unless an advanced user.
