The right version of Lightspace
Author stepanko
#1 | Posted: 17 Apr 2016 21:13
Hello. We've just purchased an i1display, and an i1pro from lightspace. They will be arriving sometime this week. we are looking to then rent lightspace, and possible buy it later on. Just wanted to check the version that is requird for my needs. I need to be able to match the i1 display to the spectro, calibrate my sony a250 oled (which as i understand i can do with the free version, as i'm not using a lut box but just tweaking controls on the sony) and also calibrate and load a lut for the eizo cg277. Will the LTE version be enough for my needs?
All the best
Stepan
#2 | Posted: 23 Apr 2016 18:19
Sorry for the late reply - NAB got in the way...
But, you can see all the various options here: http://www.lightillusion.com/lightspace_options.html
Just hover over the 'options' boxes to see what features/functions are available.
As you can see, the LTE version will work with Eizo displays.
