Profile for small hd cine 13/cine 24
Author colordrive
#1 | Posted: 23 May 2025 18:55
Hi, I´m using Colourspace Zro to calibrate a few small hd monitors.
I was able to download a few presets but cant find the ones for small hd.
Also how do you approach a calibration for 709 100 nits in a such a bright monitor?
My first approach was to tweake the max luminance to match the 100 nits when I send the 100 nits patch, and then on set I´ll push the backlight.
Do you guys think its correct how would you do that?
Thank you.
Manu
#2 | Posted: 24 May 2025 05:44
Use 2-Point RGB balance with 30% / 80% Gray patterns and evaluate using 11-Point RGB balance to see how those changes affect the whole grayscale.
Send YCbCr 10-bit 4:2:2 REC.709 signal.
After the end of grayscale, check the CMS calibration.
Check some general instructions here.
