Probe Matching — Naming Convention issue?
Author jvisuals Male
#1 | Posted: 27 Aug 2025 02:40
I've noticed that when I use my i1 Pro3 in the Configure Matching menu, the naming convention I use does not always activate the Probe Matching swatch sequence. For example:
I've used the following naming convention:
2_SPECTRO_ClientName_MonitorName_YYYYMMDD
When I go to — Configure Matching > New — and type in this naming convention, it's usually a 50-50 chance that it will activate the color patch sequence. Most of the time ColourSpace freezes up altogether.
As a means of troubleshooting, I've simply typed in the word "test" instead. This works!
I've attempted to swap the underscores with dashes, such as
2-SPECTRO-ClientName-MonitorName-YYYYMMDD
Most of the time, this works as well! But not always.
At this point, I feel that my naming convention may be too long — especially if typing in "test" seems to solve this issue.
Is this a bug I'm experiencing? I'm currently running Version 1.0.0.2146.
Or are there limitations that I should consider when using the naming convention I mentioned above?
Please let me know if you require further clarification. Thanks in advance!
#2 | Posted: 27 Aug 2025 07:40
Unable to replicate.
But I've not tested with an i1Pro3, so that may be your issue?
Try using a different probe.
If not that, you will need to provide more information on your actual workflow, or make a video of the issue using a screen recording program using something like https://screenpal.com.
