Probe Matching an i1Display Pro with a rental Xrite i1Studio Spectrophotometer?
Author muskito10
#1 | Posted: 31 Dec 2022 02:32
Hi —
I'd like to Probe Match my i1Display Pro.
BorrowLenses has an X-Rite i1Studio Spectrophotometer for rent.
Is it supported by ColourSpace HTL?
Thanks!
#2 | Posted: 31 Dec 2022 09:45
The i1Studio spectro is old, and of poor quality.
When it was available its technical standards were not good.
"Inter-instrument agreement: 0.6ΔE*2000 average, max. 1.5ΔE*2000 max"
And no, it has never been integrated with any ColourSpace license level.
(But any spectro can be used as you can manually enter the probe matching data, as per the User Guides...)
#3 | Posted: 31 Dec 2022 10:36
muskito10
Send me a msg to inform you how to import manually:
https://displaycalibrations.com/contact_us.html
