Plasma Calibration
Page  Page 5 of 5 :  « Previous  1  2  3  4  5
#61 | Posted: 20 Sep 2013 08:31
Looks to me like the probe is seeing a smaller difference than you are seeing by eye...
That wont help.
The plasma being unstable is not good either.
(What patch size are you using on the plasma, and how are you displaying it? I assume you are using the Eizo integration for that display.)
How are you applying the LUT for the displays?
Also, have you re-profiled the displays with the LUTs active and compared those profiles?
#62 | Posted: 20 Sep 2013 09:47
Oh - and I should add the Eizo is a lot more accurate than the Plasma's calibration - the plasma values are more inaccurate!
You may just be seeing the limit of the Plasma due to its instability, etc...
Author Nepomuk
#63 | Posted: 20 Sep 2013 15:26
With unstable I mean, the 3rd digit behind the comma. Maybe its the plasma noise, since I had a small patch, about 6x6cm?
Haven't tried the eizo integration. I did view a 50% grey with the DI-System and there just loaded the calibration luts for both displays. I feel I can only trust my F32 DLP.
Will try the eizo integration next.
Thanks Steve
#64 | Posted: 20 Sep 2013 15:30
What I mean is the xy values read from the Eizo were more accurate to Rec709 than the xy values from the plasma, showing that the Eizo calibration looks to be accurate - while the plasmas looks poor.
Author Nepomuk
#65 | Posted: 27 Sep 2013 10:59
The Eizo integration is great! More precise than ever!
Steve, is there a way to influence the brightness?
#66 | Posted: 27 Sep 2013 11:20
What do you men?
LUTs should not be used to control brightness - that should be via the display's own controls.
really pleased the calibration with Eizo integration is working well - it should!
Author Nepomuk
#67 | Posted: 27 Sep 2013 16:52
In the lightspace's eizo-mode the cg243w is in cal-mode, which gives no control over the display's brightness setting. Its at about 117cd/m². When I work with projector I would prefer of course lowest possible luminance of the gui display.
#68 | Posted: 27 Sep 2013 17:32
In that case you can use the 'LUT Manipulation' tools in LightSpace to lower the output.
That will work fine
Author Nepomuk
#69 | Posted: 1 Oct 2013 13:17
Thanks! Will try that!
Author sillysally
#70 | Posted: 30 Oct 2013 23:36
When profiling a K10 to a Jeti 1201 for a plasma is there any settings I should be aware of , or would it be the same as profiling a K10 to a I1Pro ?
ss
#71 | Posted: 30 Oct 2013 23:45
All the same.
Chose the best pre-set in the K10 for the display type before matching.
Job done
 Plasma Calibration
Online now: Guests - 6
Members - 1 [ twitt88 ]
