Offer by Calibrite - XRite Display Plus HL
Author Matthias Male
#1 | Posted: 1 Aug 2024 11:53
Calibrite sent me an email advertising there device Display Plus HL with a strong 50% discount, valid until 12/08/2024, offering the device at an attractive price of ~140€.
Is it worth taking the offer? Are there usable advantages over the XRite i1D3?
#2 | Posted: 1 Aug 2024 15:51
Matthias:
Not really. The only advantage the HL has is a raised upper luminance limit. An adverse consequence of this - and one you should be concerned with if you have an OLED, plasma, or CRT - is poorer accuracy near black than the non-HL meters. That has been discussed before in this forum.
#3 | Posted: 3 Aug 2024 07:12
https://www.avsforum.com/posts/62700569/
i1Display Pro Plus or i1Display Pro OEM (see FSI's store) are better options for SDR or HDR up to 2000 nits.
Author SergiSanchez Male
#4 | Posted: 4 Aug 2024 12:14
Thanks Ted,
Regarding the i1Pro2, a different problem arose.
I performed a cube profile several times with the following results:
5^ finished with no problem
15^ stopped at 3183/3443 patches with the error: i1Pro2 probe not calibrated.
17^ stopped at 4451 / 5012 patches with the error: i1Pro2 probe not calibrated.
But
I had calibrated the probe prior to calibration. The strange thing is that if you click "ok", it advances one patch and the error re-appears. So I clicked through the last 200 patches and finished the 15^profile.
I attach the 15^profile to see if you can you help me narrow down where the issue comes from. I'm running on a Windows 11 Think Pad 5th Gen from Lenovo and the issues appeared when plugged directly to the usb socket as well as when plugged through a powered usb hub.
fsi-cube15.zip Attached file:
fsi-cube15.zip
#5 | Posted: 4 Aug 2024 13:25
The i1Pro spectros have an in-built timer, and need re-calibrating when the timer expires.
So that is expected operation, and is again why using an i1Pro for actual calibration is not a good idea.
(The timer is required as the probes drift during use...)
