New LightSpace CMS profiling capabilities
#1 | Posted: 26 Dec 2013 15:26
Just because we can, and just because it's a bit of fun, we have added User Patch Sequence capability to LightSpace CMS, as well as increasing the standard maximum cube profiling size to 21^3.
These new tools are in the present Beta version, and if any users would like to play with this drop me an e-mail.
We have found a bug with the graph displays when using non-cube based patch sequences, but the LUT generation works perfectly.
The graphs display error is one we overlooked, but this has no effect on the final calibration LUTs generated, and we'll sort that ASAP.
Anyway, the result is users can use the standard in-built patch generation for any cube size up to 21^3 (ideal for those with fast K10-A probes), and also can define their own user patch set via .csv files with triplet RGB data.
This means profile patch sets can be defined with extra patches clustered around the critical 'memory colours' as desired.
Have fun, and Merry Christmas to all.
Author sillysally
#2 | Posted: 26 Dec 2013 20:08
Hello Steve.
For use with eecolor, can the eecolor store up to 5 21^3 LUT ?
Also does this have the tweaks for a BT 1886 update.
ss
Author alex_t
#3 | Posted: 26 Dec 2013 20:39
Thanks Steve,very interesting new features
#4 | Posted: 26 Dec 2013 20:50
SS, the 21^3 is for profiling.
The eeColor LUTs are 65^3 in size, and you can have as many LUTs as there are slots for in the eeColor, which is 5 or 6
With 21^3 profiling you have the ability to generate more accurate results, especially with the K10-A,
The BT1886 mods are still to come.
The parametric control capability needs a bit more work
