Murideo SIX-G and Patch Scale
Author chrisd
#1 | Posted: 11 Jan 2021 20:53
When using the Murideo SIX-G set to YCbCr 444/422 16-235, the patches from LightSpace are being scaled from 0-255 to 16-235. This makes it impossible to generate levels between 100-109% (235-255), for example. In my case I'd like to follow Ted Aspiotis' recommnded procudure for LG OLED calibration, using YCbCr patches and a patch scale of 16-255.
In LightSpace, Is there a way to use the SIX-G in YCbCr modes and be able to generate patch levels outside 16-235?
#2 | Posted: 12 Jan 2021 11:05
Hi Chris,
The YCbCr output of Murideo (with patchscale 0-255) will generate 16-235 patches.
For 16-255, you need to set Murideo to PC-Level and patchscale to 16-255 for pre-calibration/profiling.
For verification, you can use RGB PC Level with patchscale 16-235 or RGB Video levels with patchscale 0-255 to generate 16-235.
