Matching ROE LED Panels, Brompton Processing
Author dlamon1 Male
#1 | Posted: 13 Mar 2026 19:00
Recently I performed a calibration to match two different products of ROE modular LED panels.
I used a CR-100.
When matching the Primaries and Secondaries by the readings there was an obvious ( to me ) difference in color between the two products.
I matched by eye and then took readings again and the numbers were off dramatically.
What could be going on there, and how would I troubleshoot this ?
#2 | Posted: 13 Mar 2026 20:34
Using a colourimeter, without matching to a spectro on the different panels will never generate a calibration match.
Second, if the panels use radically different display technologies you will potentially hit metameric issues.
