Manual Patch Matching
Author matakus
#1 | Posted: 6 Jan 2022 11:10
Is it possible in Colourspace to manually input a patches value?
For example, colourspace displays a 255 Red Patch and then the recorded value is manually inputed, without a probe?
#2 | Posted: 6 Jan 2022 12:09
Yes - use the Virtual Probe to 'add' virtual measurement.
Then double click the point in the CIE graphs, and manually edit it.
Edit Measurement
Edit Measurement
Author matakus
#3 | Posted: 6 Jan 2022 22:07
Thanks Steve, sorry I should have been more clear - is there a way to enter an RGB value rather than X,Y value?
#4 | Posted: 6 Jan 2022 22:10
Sorry - I have no idea what you mean?
RGB values are the patch triplet values, not measured values.
Author matakus
#5 | Posted: 6 Jan 2022 22:55
Is there a way to create a LUT/Profile from a series of patch values that are manually entered, with RGB numbers, bypassing the probe.
I just want to make a LUT to align two different cameras. I could put the recorded patches on a screen and probe them but it'd be a long winded way of doing it.
#6 | Posted: 6 Jan 2022 23:07
Sounds like you need MatchLight.
Author matakus
#7 | Posted: 6 Jan 2022 23:32
And how would I go about getting that? - no links exist
#8 | Posted: 6 Jan 2022 23:44
It's all on the website: https://www.lightillusion.com/colourspace.html
Select the LUT Extraction, ICC, VCGT option from the drop down.
