Mac OS colorsync & hardware calibration
Author Jonahan
#1 | Posted: 26 Apr 2023 17:09
Let's say I have a Mac (I don't) and a monitor that supports 3D LUT calibration (I do). If my info is correct, Mac Color management cannot be turned off and it forces a display profile to be used all the time, so doesn't that mess with the monitors 3D LUT calibration?
Is the only workaround to create a ICC with no colour management or possibly just delete all ICC profiles from within the Mac like I saw mentioned in a older post?
#2 | Posted: 26 Apr 2023 19:51
We have never been able to get any Mac to have a clean output to an external display...
We have tried to generate Null ICC profiles, but have never got them to work in Mac.
And the same with trying to delete them - that's never worked either...
(Both approaches have worked in Windows.)
This is why for any grading work, a real video output card is needed - not the standard graphic card output.
Author Jonahan
#3 | Posted: 27 Apr 2023 11:38
That's somewhat surprising, I thought since many of the them are advertised as "designed for Mac", high-end monitors would be able to talk to a Mac to make sure the color management doesn't mess with the hardware calibration.
#4 | Posted: 28 Apr 2023 09:37
The Mac will try to use the EDID data from the display to apply what it thinks is the correct ICC profile via ColorSync...
Unfortunately, this fails in many situations, especially if the display is hardware calibrated to a standard that ColorSync can't match/doesn't understand.
Some monitor manufacturers have even developed their own method to try to overcome such issues - BenQ's ICCsync for example.
All this means is getting an external monitor to play nicely with the Mac environment is basically something of a crap-shoot.
The only guaranteed way to get accurate colour out of a Mac is via a dedicated video card.
