LUT to ICC convertion in ADOBE RGB space
Author EPICVIS
#1 | Posted: 18 May 2017 14:50
There are some RGB space settings in spaceman, SRGB, BT709, WIDE GAMUT RGB, PRO PHOTO.
How do I make LUT convertion in ADOBE RGB space??
I really hope Adobe RGB space added in the next update version.
p.s. my LUT is made under Adobe RGB space.
#2 | Posted: 22 May 2017 22:06
Wide Gamut is Adobe RGB...
Author EPICVIS
#3 | Posted: 31 May 2017 08:51
Thanks for reply.
According to the graph, wide gamut RGB is wider than adobe RGB.
[imgs=http://www.gamafix.lt/images/stories/duk/gamuts.png][/imgs]
When I apply wide gamut rgb for LUT to ICC, the converted Icc make less
saturated effect than original LUT.
#4 | Posted: 31 May 2017 08:59
I'll have to check the actual chromaticities we use.
We get so little interest in AdobeRGB/Wide Gamut that it's never been reviewed since the original release...
(I can't guarantee any changes will be made, as it depends on our level of existing development work.)
#5 | Posted: 1 Jun 2017 20:19
Please drop me a direct e-mail - we have a Beta version of a new SpaceMan build for you to test... Abobe RGB included - we hope!
