LUT for ECI RGB v2
Author danielv Male
#1 | Posted: 7 Nov 2026 12:25
Hello Steve
I'd like to calibrate an Asus PA32UCDM to ECI RGB v2. When I define the colour space, I can only see the option to specify the gamma – how can I set the L* curve?
Daniel
#2 | Posted: 7 Nov 2026 13:30
You would need to use the Parametric EOTF function.
Author danielv Male
#3 | Posted: 7 Nov 2026 14:08
The original profile has 700 adjustment points – should I carry them all over?
Daniel
#4 | Posted: 7 Nov 2026 15:43
https://lightillusion.com/parametric_eotf.html
"There can be as many points as needed in the list, and they must be monotonically increasing (for both ig and og). The recommendation is to not exceed 101 pairs."
 LUT for ECI RGB v2
