Looking for High-Resolution RGBW Spectral Data for RGB Laser Projectors
Author zeezed Male
#1 | Posted: 2 Sep 2026 07:47
Hi everyone,
I'm looking for high-resolution RGBW spectral data for the following projectors:
- Valerion VisionMaster Max / Pro 2
- Hisense C2 Ultra / C2 series
- Vidda C5 series
- Hisense PX3-Pro
- XGIMI Titan / Titan Noir Max
- JMGO N1 / N1S / N3 series
- Formovie Theater / Theater Premium
Ideally, I'm looking for measurements made with a high-resolution spectroradiometer, such as JETI, Colorimetry Research CR-300, Qalif, or another instrument with approximately 2 nm spectral resolution.
ColourSpace Correlation CSV files, raw RGBW spectral data, or CCSS files are all welcome.
My intention is to use the spectral data with ColourSpace HTL and SPD2Matrix for probe matching, so I'm particularly interested in the original RGBW spectral measurements, rather than a CCMX made for a specific colorimeter.
If anyone has measured any of these projectors and is willing to share the spectral data or files, I would greatly appreciate it.
Thank you!
#2 | Posted: 2 Sep 2026 08:53
Hisense C2 Ultra (RGB Laser - Brightness 100) - Qalif Spectro 1.8nm
XGIMI Titan (Dual Laser Projector) - Qalif Spectro 1.8nm
XGIMI Titan Noir Max (RGB Triple Laser Projector) - Qalif Spectro 1.8nm
Those are already available in the ZIP.
https://lightillusion.com/forums/msg.php?id=10198
#3 | Posted: 2 Sep 2026 09:18
Unless you have exactly the same lens, and same screen, etc., no Correlation Files for projectors will ever be accurate.
They can be more accurate for emissive displays, but even then that is questionable.
As you will be using SPD2Matrix you will easily see this is the case.
The whole concept of Xrite EDRs (Corr. Files/CCSS) is seriously flawed...
Author zeezed Male
#4 | Posted: 3 Sep 2026 05:23
Thanks Steve. I understand it won't be 100% accurate.
But for an RGB laser projector, could a high-resolution CCSS/Correlation File (1.8–2nm) from the same projector model still be more accurate than probe matching the i1D3 to my i1Pro3?
Author zeezed Male
#5 | Posted: 3 Sep 2026 05:24
ConnecTED
Thanks Ted, I found those three. Very helpful.
If you happen to come across any files for the other projectors on the list, especially Valerion, Vidda C5 or PX3-Pro, please let me know. Much appreciated!
#6 | Posted: 3 Sep 2026 07:14
zeezed
As per the information all over this website, and in the forums if you do a search, using a low-end spectro such as an i1Pro will just about always be better than any Corr. File. And virtually definitely with a projector.
Just use SPD2Matrix to verify this.
https://lightillusion.com/forums/tips-tricks-17/correlation-edr-ccss-files-how-accurate-1590.html
Members - 2 [ Steve, danielv ]
