Lilliput monitor LUT's
Author callek Male
#1 | Posted: 5 Oct 2021 09:26
Hi guys,
I've been using ColourSpace to profile and create 3DLUTs for my LG for some time now. With great results!
A friend of mine has a small business working with lightning for concerts and events. He has two Lilliput monitors with LUT capabilities which seem to support 17^3 cubes with RGB data order. Can I profile and create LUT's for these monitors with ColourSpace HTL or do I need a higher license level?
Cheers!
#2 | Posted: 5 Oct 2021 15:06
You would need a Professional license level.
Home Cinema license levels cannot work with professional systems.
Author callek Male
#3 | Posted: 5 Oct 2021 17:44
Is this the case even if the LUT is uploaded via USB? I would like to create a Rec 709 profile with PGenerator and export the LUT to USB stick and then upload it.
#4 | Posted: 6 Oct 2021 09:48
Yes - it is the generation of the LUT that requires a 'Professional' level license.
Author Mroge Male
#5 | Posted: 7 Dec 2022 17:21
Hello everyone, I have the same case with a Lilliput BM230-12G monitor, I would like to calibrate the color and load a rec709 lut, what license or software should I purchase or rent? I would not like to make a mistake when making the purchase. The probe to use is a 2017 Xrite 1display pro. Thank you.
#6 | Posted: 7 Dec 2022 17:59
As per the website information on the different license levels - the different LUT options, ColourSpace PRO, XPT, & INF are Lilliput Display capable.
