LightSpace Connect macOS?
Author rstolpe Male
#1 | Posted: 6 Jul 2021 09:29
I'm wondering what Framework it uses? Also will it get updated to get Apple Silicon Native support? (m1)
I'm wondering because I need a pattern generator on my MacBook m1 so I can calibrate my LG 32" 4k UltraFine display and then later Profile it with DisplayCal.
#2 | Posted: 6 Jul 2021 12:39
LightSpace Connect is an independent App.
You will need to contact the developer via the App Store/Play Store details.
(caplaz.com)
