LightSpace CMS: Probe settings while using a reference probe
Page  Page 4 of 4 :  « Previous  1  2  3  4
Author sillysally
#46 | Posted: 19 Jan 2014 14:20
Thanks Steve, very helpful and informative as usual.
ss
Author sillysally
#47 | Posted: 23 Jan 2014 11:27
If you use the K10 '0' pre-set all should be ok, as that is the base pre-set for the probe
Preset 0 for the K10 says Klein LCD.
1.Default CRT file.
2.Klein DLP Lux
3.Klein SMPTE C
4. Blank.
5.Klein TVLXVM 245
6 Klein LED Bk LCD
7. Klein Plasma.
So what preset should I use profiled by a Jeti 1211
#48 | Posted: 23 Jan 2014 11:45
default - crt.
that is the 'default' fie again which all others are based.
