License transfer
Author jamiegau
#1 | Posted: 14 Jun 2015 11:00
I was wondering, if I purchase a license, and plan to use it on a PC in a Suite and also on a laptop to make it mobile.. (IE with the same probe but typically leave the probe in the grading suite) Is this a problem as I will activate the license on two systems. Do I need to do any unregister, reregister to either system?
Ie, can I install the license on more than one system that I use?
James
#2 | Posted: 14 Jun 2015 13:03
Hi James,
Please see the 'Support' page on licensing.
http://www.lightillusion.com/support.html
The license can only be used on a single PC, and locks to the first PC it is installed on.
To run on two PCs will require two licenses - with a second provided at a discount to the first.
 License transfer
