LG OLEDC8P 3D LUT & LightSpace LTE
Author Willian Aleman
#1 | Posted: 1 Jul 2018 12:45
Does LightSpace LTE have direct support to the new internal 3D LUT capability the LG OLEDC8P – Series display Offer through the alpha 9 processor? In other words, can LightSpace LTE directly install the created 3D LUT into the LG OLEDC8P?
This to avoid using the traditional 3D LUT box approach.
#2 | Posted: 1 Jul 2018 12:47
You will need to discuss that with LG.
It is not a LightSpace issue.
#3 | Posted: 1 Jul 2018 13:13
Steve, as always thanks for your prompt response.
I don't consider this to be an issue, but a feature. Meanwhile, I got it: no.
#4 | Posted: 1 Jul 2018 13:15
It can easily be done...
But that is up to LG, not us...
#5 | Posted: 1 Jul 2018 13:44
I'm updating the studio from OSEE XCM 240/24" to LG OLEDC8P 55" as a client display.
Part of my workflow was based on calibrating the displays with Light Space LTE by the time of the purchase on August.
I'm hoping that this feature gets integrated into LightSpace one way or another soon, before mine purchase, otherwise, I might have to go with another third party calibration software that I know already has the support for this feature, but it's twice more expensive than LightSpace LTE.
Thanks once again for the quick response.
