LG 2017 REV.8 Template (for LightSpace/ColourSpace users)
#1 | Posted: 24 May 2021 10:25
It's now available for ColourSpace/LightSpace users (with HTL license level or higher) the LG 2017 Template REV.8 (B7/C7/E7/G7/W7).
Some LG Partners in content production, like Technicolor, is using a 'special' firmware for LG 2017 B7/C7/E7/G7/W7 OLED TV's which adds them internal LUT capabilities of 10-bit 1D LUT (1024 entries) and 17-Point 3D LUT (4913 individual color points) capability.
This 'special' Technicolor firmware for LG 2017 B7/C7/E7/G7/W7 OLED TV's is not publicly available for download from consumers.
These LG 2017 OLED TVs with that 'special' firmware installed, called as LG Studio (Gen 1) Monitors.
If you want to be informed about how to download the Technicolor FW, or want to access the LG OLED 2017 Template, then send a request here.
Current LG 2017 Template users can refresh their Cloud and get the new revision of LG 2017 Template.
Technicolor FW was a special version, and it will not get any updates.
You can always downgrade to consumer FW; downgrade works in LG 2017 TVs.
Technicolor FW will not support OTA broadcasting over antenna for non-US countries since it's based on US FW for Hollywood and Technicolor.
It's US FW, so it will not support App stores from other countries.
Some Apps may not work in non-US countries, for example, NetFlix will work, Disney+ will not work.
After the LUT generation, apply the videoscale pass black-filter and then select [3D] DeviceControlLG3dpro17_12bits (*.dcp) as LUT export file format.
Author timcarrdp Male
#2 | Posted: 11 Sep 2023 16:07
I would be very interested in the firmware for the C7. How do I go about contacting you?
#3 | Posted: 11 Sep 2023 18:31
