Klien K10 - decent?
Author blasetheodore
#1 | Posted: 18 Mar 2017 17:32
Anyone used the Klien K10 for calibration? (Not the K10-A). Opinions?
#2 | Posted: 18 Mar 2017 18:48
It is a lot slower than the K10-A, and cannot read so well in the blacks.
I'm not sure I'd recommend it for modern displays.
#3 | Posted: 19 Mar 2017 01:11
Ok thanks for that Steve.
Plan is to have it upgraded to the K10-A by Klien. As I understood its only a firmware and an optics upgrade that differentiates them.
It has a USB and a serial port though. If I throw a serial to USB converter on the end, will LS interface with it?
#4 | Posted: 19 Mar 2017 01:13
(would be awesome if site default was "watch this topic and get updates by email." I always forget to click.)
#5 | Posted: 19 Mar 2017 09:02
Never tested a K10 with serial to USB converter...
That is something you will have to test for yourself.
As for default 'follow threads' I'll have a look and see if it can be set.
 Klien K10 - decent?
