Jeti 1501 bluetooth
Author yovmoor
#1 | Posted: 31 Oct 2017 20:52
Does Lightspace can communicate with the bluetooth interface of the JETI 1501?
or it just in USB?
#2 | Posted: 31 Oct 2017 21:04
Yep - one of our recent users has commented on how good the Bluetooth option is...
Author Omardris
#3 | Posted: 1 Nov 2017 13:02
Yes, I can confirm that the bluetooth connection of the Spectraval 1501 works very reliably and without problems.
It should be noted, however, that the sensor shuts off after a few minutes, if no measurement takes place. This protects the battery.
Peter
Author yovmoor
#4 | Posted: 2 Nov 2017 11:42
Thank you for the infos.
Do you think it will make more easier to pass through by bluetooth than usb for a VM machine like VmFusion or Parallels Desktop with LightIllusion? Now days with USB-C I'm little concerned about USB simplicity with a VM machine on macbook Pro.
Author Omardris
#5 | Posted: 3 Nov 2017 12:22
I work only with Windows and therefore do not know myself with the Macbook.
Peter
Author yovmoor
#6 | Posted: 1 Jan 2018 16:09
For information
On Vmware Fusion 10 HighSierra 10.13.2 with windows 7 64bits sp1 on macbook pro touch bar with USB-C adaptor to USB 3 type A to a Jeti 1201 it's work without trouble with Lightpsace XPT.
 Jeti 1501 bluetooth
Online now: Guests - 74
Members - 1 [ RollsRoyce ]
