Issues with ColorSpace LTE 1.0.0.2020
Author danielv Male
#1 | Posted: 9 Oct 2024 18:05
I can no longer connect my Calibrite SL i1D3 under Windows 11 pro 23H2 in ColorSpace 1.0.0.2020.
On my Mac with Parallels under Windows 10 Pro 22H2, Colorspace 1.0.0.2020 works normally.
Furthermore, the new version has a small bug in the 3DGraph view. The drop-down list has disappeared.
Greetings and thanks for help!
Daniel
#2 | Posted: 9 Oct 2024 20:18
Please see the ? Connection Issues link on the i1D3 User Guide.
https://lightillusion.com/i1d3_manual.html
As you have stated yourself, the same version of ColourSpace working on Mac via Windows emulation shows there is no issue with ColourSpace itself.
And please be specific about the 3D Graphs issue.
What 'Drop Down'?
Author danielv Male
#3 | Posted: 10 Oct 2024 11:11
I can't find the 3DGraph Otions, they are normally displayed as a grey icon in the top right corner, right? No icon appears in my 3DGraph view, but it does in all other views. I took the term drop down list from the manual.
"The 3D Graphs icon button selects the 3D graphs within the main Profiling window.
The type of 3D Graph displayed can be defined by the Graphs Options window, 3D Graphs drop-down list, selecting 3D xyY, 3D uvY, RGB Cube, and XYZ Cube."
Kind regards Daniel
#4 | Posted: 10 Oct 2024 12:26
Those options are in 'Graph Options' window, not on the graph itself, as per the User Guides - as per the text you have posted yourself.
