Issue with ASUS PA32UCR Monitor Connection
Author ChihHuangLin Male
#1 | Posted: 13 Mar 2025 12:11
I am experiencing a connection issue with my ASUS PA32UCR monitor.
To verify the communication between my monitor and computer, I installed the ASUS ProArt Calibration software and confirmed that the computer can detect the monitor.
I have also installed the ASUS-provided drivers for the monitor, but I keep getting an "unable to connect" error. Additionally, I have tried all available USB cables and ports, but the issue persists.
Do you have any suggestions to help me troubleshoot this connection issue?
#2 | Posted: 13 Mar 2025 12:30
There are no issues with ASUS connections, so:
What ColourSpace version are you using?
Are you running ColourSpace/connecting as an Admin?
What Win. version, etc?
#3 | Posted: 13 Mar 2025 12:42
I just downloaded the latest version and opened it as an administrator. Now, I can successfully connect to the PA32UCR.
Since my EIZO monitor doesn't require administrator privileges to connect, I didn't consider this as a potential issue.
The problem is now resolved, and everything is working fine.
Thank you for your quick response!
#4 | Posted: 13 Mar 2025 13:00
With older ColourSpace versions there as an issue with the ASUS SDK that required Admn.
ASUS fixed that with a recent update, so if you were using an old ColourSpace version that will have been the issue.
With the latest versions of ColourSpace Admin. should not be required.
#5 | Posted: 13 Mar 2025 13:09
I just double-checked, and I have the latest version installed (1.0.0.2090).
I still need to run it as an administrator to connect. If I try to connect in a regular user mode, it fails.
My operating system is Windows 11 24H2, and I'm connecting the monitor via USB-C.
Just sharing this information for your reference. Aside from the previous connection issue, I haven't encountered any other major problems with this new monitor.
#6 | Posted: 13 Mar 2025 13:30
That means there is still an issue with the ASUS SDK.
(Or possibly with your monitor firmware.)
#7 | Posted: 13 Mar 2025 13:43
Thank you for providing a new perspective. I checked my screen's firmware, and it matches the version indicated by ASUS—MCM105, which is the latest version for non-North American regions.
Just for your reference. If I later confirm the issue, I'll reach out for your help in fixing it.
Many thanks~
#8 | Posted: 13 Mar 2025 13:58
MCM205 is the latest firmware.
#9 | Posted: 13 Mar 2025 14:04
I read on their website that MCM205 is only for North American users, while MCM105 is for other regions. So, I believe I am indeed using the correct firmware version.
I also checked the firmware release dates—they were released on the same day but are intended for different regions.
#10 | Posted: 13 Mar 2025 14:06
Ah - could be.
I just checked what we are using.
(And we are UK)
#11 | Posted: 13 Mar 2025 14:16
Anyway, I really appreciate your prompt assistance.
