Is the i1Display Pro probe a discontinued product?
Author carles
#1 | Posted: 13 Mar 2023 17:49
Hi to All,
I'm searching this probe in my local dealers, and I'm only finding the Calibrite ColorChecker PRO and PLUS. Does the ColorChecker Plus work with ColourSpace INF? And will work fine for calibrate HDR displays?
As different option there is the SpyderX, is that probe able to calibrate for HDR or SDR only?
Many Thanks,
Carles
#2 | Posted: 13 Mar 2023 19:01
Yes, the different Calibrite ColorChecker options are the exact same hardware as the various i1Display Pro versions.
Also, the SpyderX has basically the same capabilities as the i1Display Pro.
We use the SpyderX a fair bit ourselves.
Any such probe can be used with ColourSpace, regardless where it comes from, or what it is called.
Author carles
#3 | Posted: 14 Mar 2023 13:36
Many thanks for the answers!
Author Sato
#4 | Posted: 2 May 2023 16:34
The XRite i1Display Pro OEM version is available directly from XRite and is cheaper than getting it elsewhere. I got it a few months ago for $210 USD which is cheaper than the Calibrite Colorchecker Pro or the previous i1Display Pro Retail version.
