Importing LUTs?
#1 | Posted: 26 Sep 2018 16:21
Hi, Steve. I've been interested in importing a .3dl format LUT (9 x 9 x 9 for a Lumagen Radiance 2021) from another software package into my LightSpace HTL in order to view it using the LUT viewer capability. However, attempting to do so results in an error message that the format is not supported in the current version. Am I not doing something correctly, or is the HTL software not capable of doing this?
#2 | Posted: 26 Sep 2018 16:30
That means the LUT format is incompatible with that version of LightSpace.
The .3dl is not a home cinema LUT format, so is not supported.
(It's a professional format used by the likes of Assimilate, Resolve, Autodesk.)
#3 | Posted: 26 Sep 2018 16:56
OK. Got it. Thank you.
#4 | Posted: 21 Oct 2018 22:33
Deleted.
 Importing LUTs?
