Importing CMS from Film master
Author inaki
#1 | Posted: 29 Jan 2013 10:08
Hello,
I am trying to convert a CMS LUT generated with Nucoda Film Master to a DATA LUT for Davinci, but when I import the CMS file it appears a message error: "This format is not supported in the current version".
Can I send you the CMS file so that you analyze if it is correct?
Thank you,
#2 | Posted: 29 Jan 2013 10:12
Send me the LUT to look at - if it's a valid format we don't yet support (which is rare) we can add it.
But, do check you are not exporting the 1D LUT format from Nucoda by mistake.
There is no benefit in exporting the 1D LUT format - you need the 3D one.
Also, check the 3D LUT format settings - there are various options and you may have selected something that is making the LUT incompatible with LightSpace.
