Importing .csv LUTs in LightSpace CMS
Author Teo
#1 | Posted: 29 Aug 2012 20:52
is it possible to import .csv LUTs in LightSpace CMS. I am getting error with importing Canon C300 LUTs form their website. (I am not allowed copy/paste the exact link in this post)
I have found 2 of these 3 LUTs around on web, but I need all 3 of them.
Of course you should would prefer getting them from "source" company that have created the color transformations in camera?
Thank you!
#2 | Posted: 29 Aug 2012 21:30
No, we don't support that format. No requests for them before.
I have looked at the LUTs, and actually they don't make sense to me - for a data based workflow.
The LUTs map everything to TV legal black, or Cineon Black, with weird white points for a couple of the LUTs.
Not sure I would want to rely in them to be honest.
#3 | Posted: 29 Aug 2012 21:47
Oh, they are easy to convert to work in LightSpace.
Just open in Excel, delete the first column, and repeat the second twice, so you have 3 columns the same, and then save as a .txt tab limited file. That will then load into LightSpace directly.
Author HappyDoctor
#4 | Posted: 6 Aug 2013 21:17
Hello!
I am trying to import the LUTs downloaded from Canon for C100 camera. The files are in the .csv format.
I tried formatting the files in Excel using the procedure described above. It does not work... I tried using the first three columns and then leaving the first blank, no difference... Lightspace says "This format is not supported in the current version" Also in Excel I didn't find an option for saving the file as a .txt tab limited file... There's an option for saving as a txt. tab de limited file... Is this correct?
I want to convert this to a format that is compatible with DaVinci Resolve...
Luis
#5 | Posted: 6 Aug 2013 21:45
Yep, should be tab delimited - that was a typo by me
But, the LUTs are not good LUTs, so be careful when attempting to use them!
