The i1Pro 3 family
Author Jonahan
#1 | Posted: 29 Aug 2026 13:51
Does it matter which model of the i1Pro 3 family I pick? I assume Publish would be a waste of money since the difference between that and Basic seem to be it's printer and scanner profiling capabilities, but what about the Plus and non-Plus model? The only difference there seems to be size of the aperture (non-Plus 4,5mm and Plus 8mm), does this make a difference in display readings? I would only use if for probe matching.
#2 | Posted: 29 Aug 2026 14:36
The 'Publish' package has unnecessary additional hardware.
And the 'Plus' is of no benefit for display calibration, and the wider aperture can actually cause less accuracy with low-light measurements.
 The i1Pro 3 family
